03 explorer xlt 4.0
Old 09-25-2019 | 07:57 PM
XltSploder's Avatar
XltSploder
03 explorer xlt 4.0
What's up guys and gals, I've been having a hard time diagnosing the problem with my exp. It turns on , but won't go into gear. The driveshaft spins when I try to put it into gear but it doesnt engage into the rear axle. What could be the problem here?
Old 09-26-2019 | 06:45 PM
pbsdaddy's Avatar
pbsdaddy
Welcome to FTE. That is an unusual situation. The drive shaft is splined into the transmission and bolted to the rear axle via u bolts. So, I have to assume you are getting some spin in neutral.
I would take your question to the Explorer section and see if anyone else has had a similar problem.
Don't forget to check out the Kentucky chapter. It's a quick way to get to know some of the folks close to you.
Old 09-26-2019 | 07:14 PM
72rtchallenger's Avatar
72rtchallenger
x2 Post that question on the explorer site , more help there as they may not look at new member introductions
Old 09-26-2019 | 09:12 PM
donjamer's Avatar
donjamer
Moved to appropriate forum
Old 09-26-2019 | 10:29 PM
85e150's Avatar
85e150
If your driveshaft is turning and everything is bolted up properly to the rear axle, with the pinion turning etc. AND the vehicle does not move, then you have a broken rear axle, probably to the point where the whole thing needs replacing, case and all. It is possible to clean out a section of a ring gear, but you usually get terrific noise, clunking and worse. OR both your axles are broken.
marine232009
New Member Introductions
05-26-2009 08:41 PM
Railroad02
05-30-2008 07:47 PM
Quick Reply: 03 explorer xlt 4.0
