c6 shifter help
c6 shifter help
I have a 1985 f150 2wd with a 300 straight 6 and a c6 trans. I pulled the engine and trans out of this truck to reseal the engine and trans about 2 years ago when I was still working a Ford for my boss. when we found out that crank was grooved to hell it got put on the back burner. Since then I have quit and now my old boss wanted me to put the engine and trans t at my house.
the problem I am now running into I dont remember how the shift linkage goes any pics or link would help alot.
The shifter arm is the one closest to the trans, when you move it, it will have detents it clicks through. Grab the output shaft, move the arm as far as it will go. If you can't turn the shaft anymore that is "park". If you can still turn the shaft that is "L1". Move it all the way the other way and it should lock the output shaft and that is park.
red66rider
25
12-18-2016 09:22 PM
Don Vito
10-28-2015 01:55 PM
custom1106
03-30-2014 02:33 AM
