2019 F250 & Sled Deck
Mannnnnn, I want that drawer! haha How many times have I cursed on crawling in under the deck to get that gas can that managed to find it;'s way forward. Silly messy after a 6Hr haul across the island. Awesome looking setup!
I added some rock lights to the bottom sides of the slide outs for the late evenings back to the truck, great cheap addition if you were ever interested.
I had a '13 gasser before this, you'll love this one with 2 sleds above it!
As for the drawer, its a must with the deck...I hate crawling back there. I also added a beaver trail extension (~20") to better support the long track - folds out of way during season and I take it off in summer.
Awesome. I don't have any on the headache rack, as the rack on the Marathon deck is a bit lower than the cab, so I'd be running some weird looking extensions to clear the cab for forward lighting. Just running some grill lights for the time being, pictured below:
As for the deck, there's 4 rock lights on either side, evenly spaced. I've also got 2 2" Squares mounted under the ramp bar to assist with loading and area lighting - worked pretty well this past season.
You've got me off my **** today, just ordered some bearings to make myself an under deck drawer. No crawling fr me next season! haha
I don't trust the tie downs for a second. Your experience may vary, but I know I've hit potholes that would have cleaned out the tie downs or turn burckles. Don't want to think about what would happen in an accident.
I drilled the holes. Deck sits on 4 3/4" plywood squares, grade 8 bolts down through the bed with 2" or 3" backer plates. Obviously bigger would be better. Caution to the Drivers forward mount, you're drilling right on top of your fuel and DEF fill lines, and there's very little clearance.
I apply never-seize to the plates and holes to prevent corrosion, and I'm only running the deck in the winter, so I clean it up in the spring when I remove the deck. Ideally you'd want to run a separator (piece of rubber?) between the backer plate and the bed for dis-similar metals protection.
Truckboss decks bolt to the bed floor and have tie downs. My drives can be pretty far some times and at highway speeds I dont wanna see my deck pass me! I looked at them all before settling on this one - it wasnt an easy choice cause they're not cheap, but by far the best engineered and flexible. They really are more hassle than a trailer (and they do get more grime), but I was getting 3-4mpg less pulling the trailer and it a much less stressful drive.
I have a marathon deck like in the pic (older style). Wondering did you drill and install with supplied backing through the aluminum bed floor or did you use the tie down points. I drilled on my last truck but wondered what people were doing on these newer aluminum bodied trucks.
Definitely messier than an enclosed, but I find it miles ahead of the open trailer pictured on my truck above - I'll drive myself with just one sled aboard instead of putting my sled on that.
I was going to place a few rear ward facing squares on the headache rack, as I had them there before on a previous setup, but found them blinding getting the sled up there, and didn't help too much when strapping down. I just use the cab light now and find that ok.
1994F2507.3L
34
12-22-2010 07:31 PM
