78 bronco new purchase
Notice that the part number for the Bronco Ranger emblem is D8TZ-16720-B .. If there was no Bronco Ranger for 1978, why would there be a 1978 part number for the emblem?
Ridiculous! No parts catalog, no clue. So called 'expert' needs to
D8TZ-16720-A .. Bronco Custom Nameplate = 1978/79
D8TZ-16720-B .. Bronco Ranger Nameplate = 1978/79.
D7TZ-16720-BD .. XLT Nameplate = 1977/79 F100/350 & 1978/79 Bronco.
Point is, the parts book is just that. A parts book. It doesnt tell you everything. Yes, you can glean a whole lot of info from it and you may be right. But being rude to people isnt what this forum should be about. We all appreciate your knowledge and input, but there is a way to do pass on that knowledge with more tact.
We should acknowledge that not everyone knows everything about these trucks and be positive about correcting errors. If we all knew everything, there would be no need for a forum.
Yes, but that doesn't equate to there being Bronco Rangers being offered without XLT trim. If we are going by that logic, then there could be Bronco Custom XLT's, but I don't think that happened.
Point is, the parts book is just that. A parts book. It doesn't tell you everything. Yes, you can glean a whole lot of info from it and you may be right. But being rude to people isnt what this forum should be about. We all appreciate your knowledge and input, but there is a way to do pass on that knowledge with more tact.
The upper fender and door mouldings with the black vinyl inserts used on 1973/76 F100/350 Ranger XLT's were also used with Race Tracks.
Notice the D3TZ (1973) part number prefixes for these mouldings in posts #16 & #18.
Bronco XLT came with upper bodyside mouldings with black vinyl inserts and wheel opening mouldings.
Bronco Ranger was the most expensive, came with Race Track mouldings.
The factory punched out holes in the sheet metal for mouldings, while dealers and owners drilled out the holes, so will have burrs on the backside of the sheet metal.
Plus, over the years some people added mouldings, some people removed mouldings, then filled in the holes.
The Bronco Ranger XLT in the pic did NOT come with any Race Trac mouldings. Guess maybe the original owner ordered it that way? Could you order it that way? No sign that any holes were factory punched, then filled in. Yes it HAD upper body side and wheel wheel mouldings.
BRONCO RANGER with Race Track Mouldings. AFAIK, there was no such thing as a Bronco Ranger XLT, so it's possible that someone added the Bronco Ranger nameplate.
This Bronco is 41 years old, has probably had multiple owners...and you know how some people love to swap parts around.
I've never owned a Bronco, only driven one once, rented it from Hertz 12/91 while vacationing in CO
When I-70 suffered a white-out, I had to read the owners manual to figure out how the 4WD worked.
Regardless of what the parts manual shows, that Bronco had, front bench/folder seat, carpet, kick panel carpet, glove box trim ring (plastic one), glove box door wood grain overlay, wood grain vinyl over lay with chrome piece on the doors, a/c, brown sun visors and headliner. Chrome Sport rear bumper. Had only 90,000 miles on it. Black large size head type 9 mirrors. Cruise control added on aftermarket to the t/s lever. NEVER looks to have had race trac trim.
#28
It seems like I've seen alot of broncos with the XLT badge.
#29
