New Wheels and Tires
In the specific size I wanted, the F / 12 rating and the max load rating is about as good as you are going to do, if you want a custom setup, but still high specs for towing. Toyo are great tires too. These are just a better bang for the buck. I think the tread pattern on the Nitto Grapplers are better for roads and towing than the aggressive pattern on the Toyo.
The following 9 users liked this post by GoldenDomer:
The following users liked this post:
The following 2 users liked this post by RandyinTN:
The following 2 users liked this post by hctrble:
So far no vibration issues. Honestly, the only complaint I have right now is the steering feels a little loose every so often. I just ordered all new Fox 2.0's and the Fox ATS stabilizer so that should tighten things up a bit. Honestly, I'm not sure if the wheels are hub or lug centric. I know the difference but not sure how to tell for a specific wheel. I know these are drilled for my specific bolt pattern.
I just installed the Fox ATS SS today but not much drive time on it yet. And have the Fox 2" smooth bodies all 4 corners. Shocks made a really noticeable difference IMHO. All from Stage3 Motorsports.
No lift or level though. When spotting placement on the Fox ATS, be sure to have someone hold the steering wheel against the stop to get the right placement for the drag link clamp.
#30
Im looking to do something similar, and see what the plow prep can do without actually installing a kit. Any rub?
