76 F250... driveshaft angle??
Old 02-28-2019 | 05:19 PM
tbear853's Avatar
tbear853
I've cut perches off and rewelded, , but only after dropping pumkin (removed axles first) or just popping rear cover on the other (like a Dana in a race car), to drain rear end lube out before welding.
Just not sure the heat on the inside of the axle tube and lube will play nicely?
I have done some short duration welding in stitches on '07's oem shocks I was shortening solid steel bottom stalks (not welding to shock body itself) on … to lower my '07, but I cooled those shocks with water between stitches. I suppose same could be done with perches, but I'd want those burnt in good.
  #32
Old 02-28-2019 | 07:05 PM
alans77crew's Avatar
alans77crew
Correct me if I'm wrong but isn't a 76 divorced t-case?
FordF350Baby
06-06-2009 07:02 AM
73 ford guy
Offroad & 4x4
13
10-27-2008 12:10 AM
f350rebel
1999 to 2016 Super Duty
09-03-2007 05:21 PM
Screamin T/A
Offroad & 4x4
11-17-2004 02:16 PM
79BroncoJD
11-10-2002 12:02 AM
Quick Reply: 76 F250... driveshaft angle??
