1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Another cruise control problem.
Old 01-31-2019 | 02:22 AM
Flip420's Avatar
Flip420
A couple quick questions. On a 2001 xlt f250 are the steering wheel buttons supposed to light up when you turn the lights on? If they don't, is that likely the clock spring? And does that self diagnostic test work on this year truck? I've tried and no lights come on I the dash. Thanks.
Old 01-31-2019 | 11:57 AM
brian42's Avatar
brian42
Yes, the buttons should light up when you turn your lights on.
That does sound like it could a clockspring issue. Do your horn and cruise control work? I know your title is "Another cruise control problem." but you don't say what is wrong with it and I don't want to assume.
I'm not sure what self-diagnostic test you are referring to. There was a major electrical change starting with the 2002 MY so I don't know what I have that you may/may not have.
Old 01-31-2019 | 12:22 PM
Flip420's Avatar
Flip420
It doesn’t work at at all
Sorry no cruise light on dash or steering wheel controls . Horn does work.
Old 01-31-2019 | 01:31 PM
brian42's Avatar
brian42
Have you checked the brake pedal switch?
It seems more like an electrical issue since you don't have lights either. I don't see a dedicated fuse in my owner's manual but you can trace schematics for free here if you want to check the wiring:
https://www.ford-trucks.com/forums/1...l#post17412306
Old 01-31-2019 | 02:39 PM
CousinCarl's Avatar
CousinCarl
I'm with Brian. A broken clockspring would cut all electronics at the wheel, and wheel only. You'd also get an airbag idiot light - IF your dash lights were working.
millejas
04-22-2018 05:58 PM
steve06F250
04-24-2013 03:27 AM
alamoadam
Electrical Systems/Wiring
04-07-2009 11:42 PM
Marky Marc
10-15-2003 08:33 AM
