2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Those of you with a lift and rear sway bar...
Old 01-29-2019 | 06:18 PM
2017-350's Avatar
2017-350
For the people with a lifted truck, specifically 4'', did you put aftermarket sway bar end links as well? I have a rear sway bar and noticed the links are angled now since the lift. does it make a difference?
Old 01-29-2019 | 09:17 PM
Imadentguy's Avatar
Imadentguy
Yes you need longer end links.
Old 01-30-2019 | 03:38 AM
Lindenwood's Avatar
Lindenwood
The rear was lifted 4" over stock??
In any case, it is up to you. As-is, the angled sway bar arms will actually increase lateral stability, better offsetting the naturally-increased rollng tendency of the higher center of gravity.
Adding longer links will reduce roll stiffness, but make the ride slighlty more supple when one side of the vehicle goes over larger bumps.
Honestly, if you don't do much off-road driving, I'd leave em.
FWIW, I offroad pretty regularly and have no anti-sway bars at all. However, I might reinstall the front when towing after I lift the truck.
bignast1
1999 to 2016 Super Duty
03-03-2017 08:26 PM
savagebagz
08-07-2016 10:08 PM
damuddog
07-31-2008 10:41 AM
River Runner
11-05-2004 10:57 AM
will-work -for-mud
09-25-2003 12:18 AM
