2008 f250 leveling kit removal questions
Hey all new to the forums. I recently picked up an 08 F250 with the 6.4. Truck has a revtech 6125 leveling kit already installed. I love the way the truck looks, however I have an issue with the way it tows. I have a 30 ft gooseneck that gets pulled from time to time when they dually (it's a dirtymax we won't go there) is unavailable. I hooked up to it a week ago. Had a mild load on the trailer, disk mower and duals of a tractor. So wasn't overloaded by any means. Now the issue happened around 45mph. The rearend of the truck started hoping pretty bad. I'm guessing from the fact that the rearend was sitting pretty low compared to the front while not actually having much weight on the suspension. Then today I was hooked to a 16ft dual axle bumper hitch trailer with a small tractor, about 2200lbs. Had some small stability issues, that should not happen, minor fishtail in the trailer. I've pulled same setup behind an 01 Yukon and it pulled fine, a little pissy, bit fine.
So, I looking at removing the leveling kit and putting back to stock height. The front blocks look like they can be removed and just reassemble all parts. The issues is I can't find out what the stock blocks for the rear are or what parts are needed. Any input would be much appreciated.
If it has aftermarket rear blocks, then it is isn't just leveled, it has full lift. The problems you are describing sound like they have nothing to do with leveling/lift kit. Sounds like you have something else going on. If the trailer is fish tailing, the easiest problem to remedy is hitch height. If the problem persist, I would begin to look at suspension components. The leveling kit is not the cause of this.
