Oil dipstick tip broke off
Old 09-08-2018 | 05:53 PM
ithaca1230's Avatar
ithaca1230
While pulling out the dipstick the plastic tip at the end broke off into the tube somewhere. Is this an issue? Should I be concerned or just let it sit in the oil pan?
Thanks
Old 09-09-2018 | 07:16 AM
DSMMH's Avatar
DSMMH
I would leave it. It will float on the oil and should not get any where near the oil pump intake. You might get lucky the next oil change and it will drain out. Worst case is the oil pump grinds it up and it get trapped in the oil filter.
Ed
Old 09-09-2018 | 01:05 PM
housedad's Avatar
housedad
Don't you just hate it when that stuff happens? you end up worrying about ti forever. I went out to check the oil one day last year, and the dipstick was gone! No sign of a stub or the stick in the tube. I even removed the tube to check if the stick had fallen down. No joy. I still wonder what happened to it.
Old 09-09-2018 | 04:03 PM
Delta1166's Avatar
Delta1166
Old 09-10-2018 | 12:29 PM
ithaca1230's Avatar
ithaca1230
I just ordered a new one. Will get it tomorrow. I had to change the hose that goes to the Bulletproof Diesel filter and changed the oil. last thing I did after oil in was check the oil level and I heard it snap when I was pulling it out. Just the way it goes sometime.
Old 09-10-2018 | 03:19 PM
Stewart_H's Avatar
Stewart_H
Ed, with his 6.0L PSD, if that happened, he'd probably have a trashed HPOP and some (if not all) of his injectors would need to be replaced.
The diesels injectors are driven by high pressure oil so there can't be minute, plastic parts suspended in the oil or drastic, bad things can happen to a 7.3L or 6.0L diesel. Something would get by the filter (Murphy strikes) for sure.
Stewart
Edit: Sorry, I know that's a Debbie Downer situation, but thinking worse case scenario can help in the long run sometimes.
Old 09-11-2018 | 08:55 AM
ithaca1230's Avatar
ithaca1230
So do you guys think I should drop the oil pan?
Old 09-11-2018 | 01:27 PM
Stewart_H's Avatar
Stewart_H
All kidding aside on the worse case scenario, would the plastic piece even make it into the oil pickup? Isn't it too big?
Stewart
Old 09-11-2018 | 07:45 PM
Tuquala's Avatar
Tuquala
Haven't seen one in person, but the 6 leaker must have a screen on the pickup tube. Never seen an engine without one. So as Stewart has stated, it would probably never make it to the pumps!!! Simple science.
Old 09-12-2018 | 09:34 AM
ithaca1230's Avatar
ithaca1230
Thanks for all the responses!
Old 09-12-2018 | 12:22 PM
pirate4x4_camo's Avatar
pirate4x4_camo
If it were mine I would change the oil and get the piece out, If it didn’t Come out the first time I would put the old oil back in and keep the flow going until it washed out and I retrieved the piece. That said the pick up screen should/will stop it from entering the oil passage to the pump But if it were to enter the passage i think it would get stuck before the pump and likely block flow to the pump which would seize whatever bearing is first to get oil on a 6.0. #1 main bearing is my guesss without looking at the oil flow schematic that is just a guess.
Old 09-12-2018 | 12:48 PM
PrescottIce's Avatar
PrescottIce
I'd drain the oil and use a strategically bent piece of copper wire through the drain hole to fish around the bottom of the pan.
Old 09-12-2018 | 01:51 PM
TooManyToys.'s Avatar
TooManyToys.
I wouldn't put a lot of hope in that it will come out by itself or fished out based on the collar of the 6.0L oil pan drain unless it's swirling in the vortex and broken smaller then the threaded hole. It may, or never.
Old 09-12-2018 | 02:42 PM
PrescottIce
Ah. Hadn't thought about that.
Lex2002
24
11-18-2018 07:56 AM
Iaff113
10-11-2014 02:49 PM
guitarpicr
09-10-2012 10:21 PM
'86_150
11-08-2009 09:36 PM
flounder
02-17-2004 12:25 AM
