fummins conversion
#46
Set up properly 300-350 hp will give you years of good service, a guy on a Cummins forum has over 400,000 miles on his that's making 320 hp.
That's nearly 650000 km for you guys.
Mine hasn't been dyno'd but should be around 300-350 hp, it does a good job hauling my loads at that level, I can turn it up more but it starts running to hot and puts a lot of stress on the rest of the drive train.
Long term reliability is what I want from my truck, didn't get that from the 6.0
#50
Sweet!
Built date August 7 1995, that makes it a early 96 model 215 engine but still has the spin on fuel filter, that's a plus.
Engine # 56233678 is the serial number for that engine, if you ever need any parts from Cummins that's the number they'll need to look up the parts.
Vacuum pump, power steering pump and all of the throttle linkage is there, even the turbo's exhaust elbow, and you said there was some wiring also
Looks like you got a complete package, that's much better than a stripped down engine.
#51
Yeah great as i mentioned whilst its a daily itll be 300 350hp cause im not intrested while its a daily. But i think ill grwb the dearer clutch cause i dont for a very long time wanna have to buy another from the states. And for the extra 300 od us im happy to go with it.
i wished i new someone in Australia rhat had done this swap to go for a spin..
what gearbox cooling did you go with destroked450? Radiator to the gearbox? Or external setup
#52
Its also coming with engine fan,kdp and new crank seals. Timing cover seal for when i do the kdp. Full harness. Fresh oil is in the truck also. He is dearer than some importers but hes an ex diesel mechanic so cant hurt paying a little more for a legit engine i reckon.. oh and brand fss and lift pump.
#53
I understand about the clutch, being where your located and the shipping cost, be aware that a double disc clutch will cause the tranny to shift slower.
I'm using the radiator cooler, but if I ever take the trans out for any reason I'm going to mount a external cooler up between the frame rails behind the transfer case.
Every time I need to do any maintenance under the truck those cooler lines going the the radiator are in the way.
#54
#56
#57
#58
