2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
How exactly does regen work?
Old 04-08-2018 | 11:59 PM
HRTKD's Avatar
HRTKD
Boondocker
Mine always goes to 0% unless I interrupt it by putting the transmission in Park.
There is a thread in the 6.7L subforum about a product called Enerburn. It helps reduce the frequency of regens. I don't use it but I'm thinking about. The thread is an interesting read as it takes you through the thought process of how the truck goes about doing and deciding when to do a regen. Here is a link to that thread: https://www.ford-trucks.com/forums/1...-enerburn.html
Old 04-09-2018 | 09:24 AM
1956Fatfenders's Avatar
1956Fatfenders
For those looking for the coffee table books, the link to them, is in the "Some Tech Info, Read First" folder, at the top of this forum.:
Coffee Table Books - Diesel Technician Society
Old 04-09-2018 | 05:48 PM
OEM's Avatar
OEM
Originally Posted by PremierPOWER
Where/ how does it inform you that you’re going through a Regen? I have 1,300 miles on my 2018 and have no idea?
Originally Posted by MJMETHOW
I have no idea either,nothing lights up in the dash.
This screen came with my truck. I'm assuming its because I have the operator commanded regeneration.
Old 04-09-2018 | 07:41 PM
roadpilot's Avatar
roadpilot
This item can be added to the screen for any 17+ PSD, with or without the operator commanded regeneration. I added it to my Platinum using FORScan.
Old 04-09-2018 | 07:45 PM
roadpilot's Avatar
roadpilot
Originally Posted by USSenator
I completely ignore regens except to fill my DEF tank...
DEF is not part of the DPF regeneration process. DEF is sprayed into the exhaust stream of diesel vehicles to break down dangerous NOx emissions into harmless nitrogen and water. The regen process uses HEAT to burn off the soot that accumulates in the DPF and turn it into ash residue.
Old 04-09-2018 | 07:53 PM
PremierPOWER's Avatar
PremierPOWER
what other misc. screens are turned off that Forscan/ dealer can turn on?
Old 04-09-2018 | 07:54 PM
OEM's Avatar
OEM
I know. I was just pointing out that with the OCR it is a standard screen that you don't have to add after the fact.
ZuluFoxtrot
2017+ Super Duty
01-27-2018 08:10 PM
baronmic1
2015 - 2020 F150
21
04-17-2017 10:32 PM
Ricohman
6.7L Power Stroke Diesel
08-11-2015 10:44 AM
MarkMoore
12-17-2010 07:22 AM
Cowboy350
04-20-2005 11:45 PM
Quick Reply: How exactly does regen work?
