Need help f250 rear brake parts
All 1956/65 F250's and some 1966/75 F250's have 12 1/8" x 2" brakes.
Beginning in 1966 on F250 Camper Specials and F250's with a 7,500 lbs. Gross Vehicle Weight Rating, the brakes are 12" x 2 1/2."
Here's the picture. The caption is wrong, because the narrow 12 1/8" x 2" shoes used different parts than the wide 12" x 2 1/2" shoes.
For an example, the 2068 hold down springs are different.
Several years ago had similar issue with 65 F100 and I was able to replace all components thru local Napa store. Imagine a reputable local auto parts can find the parts. If decide to go thru local source suggest take old drum and shoes, believe there are a couple 250 sizes? Initially had issue with aftermarket brake components and ordered thru popular Ford part supplier's only to find the items were imported, matter of preference.
I found the brake hold down kit and the rear brake shoe adjustment kit very helpful in reassembling the rear brakes.
mauser9
06-15-2015 12:38 PM
webstar61
01-13-2013 12:07 PM
