1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2002 F350 V10 Replce engine oil pan gasket
Old 01-11-2018 | 08:59 PM
Byoung Oh's Avatar
Byoung Oh
I just found out that my father's 2002 F350 V10's oil pan gasket is leaking. I thought it might be the rear main seal, but upon closer inspection, I only see leaks around gasket toward transmission.
I know that the engine has to come out (or raised up significantly) to remove the oil pan. But is it possible to replace gasket without removing the engine?
I think there will be enough room to clean gasket surface, but I'm not sure if the gasket can be installed. I'm worried about the oil pickup tube the most.
Stickz
49
02-17-2013 10:39 AM
khadma
1997 - 2003 F150
09-09-2012 07:31 PM
parr4
04-08-2011 09:11 PM
oldcoupe42
34
07-07-2010 09:10 PM
Fluorspar1
03-27-2003 08:41 PM
