Respect and appreciation for my 73 f251 camper special. 5.9L v8 360
Old 09-13-2017 | 07:40 AM
Studlee509's Avatar
Studlee509
My brother in law blessed my socks off by selling me his 1973 f250, when I paroled,on a monthly payment plan. It's a beautiful truck and I've always had a thing for old fords. It is the only thing of monetary value in my life. So in turn, i take great care of this blessing. Moments where a blessing feels like a curse happens a little too often, but i love working on her. I have learned alot over the last year with my daily driver, but right now I am completely stumped on my overheating issue. I have replaced: air filter, plugs,wires,cap,rotor,points,radiator,thermostat,r ebuilt carb, new vacuum hoses,coolant hoses, belts....bought an engine analyzer, timing gun, vacuum gauge. I followed all steps and procedures from manuals and you guys even more so. Curb idle, timing, carb adjust and tune, dwell, choke and high idle...all these things were set to specs....why is my truck still overheating? I have not replaced my distributor but bought an electronic motorcraft one from a 1978 with a part #D7TE 12127 hoping it's compatible. Has anybody else gone through this and conquered? Just finding the same 18x24 core radiator was a fiasco. Any advice?
Old 09-13-2017 | 08:28 AM
CelticOne's Avatar
CelticOne
Regular User
I don't have the answer to your question but I just wanted to say that I appreciate your attitude of gratitude and outlook on life. I pray that you continue on this path and find the many more (unexpected) blessings that come with it. Have a great day, my friend.
Old 09-13-2017 | 08:42 AM
4fords's Avatar
4fords
Is the fan/radiator shroud still in place on the truck to make sure its pulling "good" air? Is your fan clutch working properly? Just a couple of things that come to mind.
Old 09-13-2017 | 09:03 AM
BeauF0RD's Avatar
BeauF0RD
No answers either, but compliments on a beautiful truck.
Old 09-14-2017 | 10:47 AM
77F350RangerSCS's Avatar
77F350RangerSCS
Nice truck.
Is the water pump pumping? It's not on your list of replaced/checked components.
Old 09-14-2017 | 05:16 PM
72rtchallenger's Avatar
72rtchallenger
Originally Posted by 77F350RangerSCS
Nice truck.
Yes agree check water pump and check circulation of heater core as it could be clogged up , you can bypass it and see if it still overheats or not,, but water pump could be out or failing..Have you flushed the block ?
Old 09-14-2017 | 06:13 PM
77F350RangerSCS
Also by overheating do you mean steaming, blowing coolant out of over flow etc or the gauge/warning lamp is reading over hot?
Old 09-15-2017 | 06:21 AM
Studlee509's Avatar
Studlee509
Nice truck.
thank you! I have not replaced water pump. Thats probably it huh.? Electrolysis smoked my impeller
Old 09-15-2017 | 06:23 AM
Studlee509's Avatar
Studlee509
1973 Ford F-250 Camper special
All of the above. And thank you for the reply
Old 09-15-2017 | 06:29 AM
Studlee509's Avatar
Studlee509
i have drained so much as what comes out of lower hose when swapping radiators. 3 times....lol. first time pulled radiator and tried soldering. Worked for couple days. Second time same thing. Third time bought and installed wrong radiator cause i needed to get to work and had no other options. 4th time finally found correct fitting radiator, which i picked for $35! It is a 3 rowb
Old 09-15-2017 | 06:30 AM
Studlee509's Avatar
Studlee509
thank you!
Old 09-15-2017 | 06:33 AM
Studlee509's Avatar
Studlee509
Originally Posted by 4fords
Is the fan/radiator shroud still in place on the truck to make sure its pulling "good" air? Is your fan clutch working properly? Just a couple of things that comee to mind.
yes radiator is shrouded. I have a fixed fan, no clutch, no a/c
Old 09-15-2017 | 06:35 AM
Studlee509's Avatar
Studlee509
Thank you celticone
Old 09-15-2017 | 01:18 PM
72rtchallenger
I would hook up a water hose an flush the block as well as flushing the heater core by using the two heater hoses and see if that helps . It could have gotten clogged up just because you drained the system an loosened up sediment .
Another thing is did you changed radiator cap ? If not it may be bad an not holding pressure
B327Thr
01-06-2019 09:13 PM
spltend
01-21-2015 01:21 PM
wallster
13
08-21-2012 06:47 AM
F-250 restorer
03-29-2010 12:11 PM
F-250 restorer
03-26-2010 11:10 PM
