Longer pitman arm, improved turn radius?
An interesting experience relayed by a friend has been making me think: he had an f250 and changed his pitman arm when he raised it to an offset arm from an F350. He said his turn radius improved dramatically. He said it seemed about half an inch longer than the f250. Wonder if anyone had had a similar experience?
He said it would hit his bump stops after the change and so he wasn't worried.
Will mine doesn't hit the stops right now. The traits sucks, but never considered and other option. And after looking at some arms online, the center of hole on F350 is. 25" longer
Wouldn't a fraction of an inch equate to a noticeable difference in turn radius though? If I'm not hitting the bump stops, I am not turning as sharply as I could conceivably turn. Seems like a worthwhile mod if it has no other adverse side effects. Part of the reason I posted this question is in the hope that someone has some experience before I try it.
Has anyone else had someone else turn the steering wheel and see if they hit the bump stop? The trick is 4wd,so I expect a larger raid, but when I saw that it didn't, then I assume it is at the gearbox limits,and not the limit of the wheels.
nkapphahn
Ford Truck Parts for Sale
05-01-2012 12:50 PM
snaponprofile
03-11-2012 08:43 PM
dakonthemountain
07-26-2011 06:08 PM
