Alberta Chapter Join Chapter, Leader: Puddy
ALBERTA CHAT - Forevere more!
Old 12-03-2022 | 08:14 PM
Fomoko1's Avatar
Fomoko1
Either a gate or a net will keep cargo in the box. I have both tailgates for my F250, the regular one and a flow thru. The low thru tail gate is pretty cool.
  #11717
Old 12-03-2022 | 08:19 PM
56panelford's Avatar
56panelford
I'll see how it goes, thinking of building a tool box for it at some point to have some place to put groceries or items when we go shopping..
  #11718
Old 12-03-2022 | 08:22 PM
Fomoko1's Avatar
Fomoko1
I'm sure you`lll come up with lots of ideas, I've seen some pretty neat storage boxes on vintage trucks. I wish I mounted the gas tank in the box of my 53 instead of under the box at the back, it would have made life a lot simpler.
  #11719
Old 12-03-2022 | 08:31 PM
56panelford
I had different plans for my tank until some things changed in the build..
  #11720
Old 12-03-2022 | 08:38 PM
Fomoko1's Avatar
Fomoko1
Changes part way a project makes a lot more work.......don't ask how I know that.
  #11721
Old 12-03-2022 | 08:41 PM
56panelford
At least I hadn't already installed a tank before I found out my idea needed to be changed..
  #11722
Old 12-03-2022 | 08:45 PM
Fomoko1's Avatar
Fomoko1
I guess I could put my 53 tank inside the pick up box but that takes time and I still have enough to do.
  #11723
Old 12-03-2022 | 08:49 PM
56panelford
Why don't you like where it is now, where is it..?
  #11724
Old 12-03-2022 | 08:55 PM
Fomoko1's Avatar
Fomoko1
I can't mount a rear bumper which I want plus I don't like the idea of cutting up the box floor boards for the gas fill.
  #11725
Old 12-03-2022 | 09:02 PM
56panelford
You have a Mustang tank..? You were going to post pictures once but that never happened..
  #11726
Old 12-03-2022 | 09:16 PM
Fomoko1's Avatar
Fomoko1
I put the Mustang gas tank underneath the frame at the back like I did with the 56 M100 that I had. Can't find pictures of it tho, may have erased them.
  #11727
Old 12-03-2022 | 09:26 PM
56panelford
So to put the bumper brackets on is it just dropping the tank to put them on..?
  #11728
Old 12-03-2022 | 09:38 PM
Fomoko1's Avatar
Fomoko1
The tank takes up all the room and it`s at the very back of the frame. So far I don't see any way have a bumper and have the gas tank underneath at the very back of the frame.
  #11729
Old 12-04-2022 | 08:22 AM
56panelford
The brackets bolt to the side of the frame so shouldn't be a problem other than lowering the tank to install the bolts..pictures would help..
  #11730
Old 12-04-2022 | 02:45 PM
Fomoko1's Avatar
Fomoko1
I'll check in the spring but I'm not sure if there is enough room for the bolts between the frame and the tank.
Quick Reply: ALBERTA CHAT - Forevere more!
