ALBERTA CHAT - Forevere more!
02-18-2021 | 08:07 PM
02-18-2021 | 08:15 PM
I'll see what happens after I add the extra plug-in and breaker..
02-18-2021 | 08:27 PM
I'm sure you spend time messing with the plasma, I did at first.
02-18-2021 | 08:32 PM
I need to find some scrap to play with..
02-18-2021 | 08:40 PM
That's how I started, practice is very helpful.
02-18-2021 | 08:45 PM
How long before you became a pro..?
02-18-2021 | 09:03 PM
I'm still working on it.
02-18-2021 | 09:13 PM
Things should be better once I get this breaker installed and a new plugin installed.
02-18-2021 | 09:15 PM
I did find that a plasma definitely works better with power.
02-18-2021 | 09:22 PM
It was working off the 15 amp fuse but kept blowing the fuse, it calls for a 20 amp
02-18-2021 | 09:31 PM
I'm not sure what mine draws but likely the same.
02-18-2021 | 09:34 PM
So far I'm pretty impressed with the way it cuts the little bit I used it but didn't want to keep tripping the breaker in case it hurt the machine..
02-18-2021 | 09:47 PM
Shutting down under load could be hard on it, I know my computer doesn't like that.
02-18-2021 | 09:49 PM
That's why I quit while I was ahead...lol
02-18-2021 | 09:52 PM
It must be hard to get started then breaker trips.
