mis fire codes po316 and po300
Old 05-01-2017 | 10:39 PM
2006f150bk's Avatar
2006f150bk
hi name is brandon new to this site and im needed some advise here with my truck. I bought a 2006 f150 fx4 it has the 5.4 liter in it. When i bought it i already new it needed a tune up just by they way it drove it had no power and it would backfire at high RPM. So long story short i spent a day and changed the plugs and all 8 coil packs and i used all motor craft plugs and coil packs. After i did that it was like night and day difference ran like a dream. Well now about two weeks later i started to notice that it was idling rough not bad but just enough to notice that it was. Check engine light came on and i hooked up my scanner and it was giving me codes-PO316&PO300 and PO1000. this is where it gets weird i unhook my scanner and start the truck and the light was off im okay great i just left it alone. Three days later while i was driving to work the light came back on and was giving me the same three codes. Im at loss where to start now
Old 05-02-2017 | 02:16 PM
steve(ill)'s Avatar
steve(ill)
you have a random misfire, misfire on startup, and initial checks not completed on startup. I would worry about the first two "misfires". You don't have a specific cylinder narrowed down.. It could be a specific cylinder or it could be the shaft position sensor that is giving bad timing / fire... You can try the sensor, or keep running until you get a specific cylinder code , if ever.
Xcursion88
2004 - 2008 F150
06-06-2018 05:06 PM
5.4Triton
1997 - 2003 F150
15
03-30-2012 08:36 PM
richis69mach
1997 - 2003 F150
04-21-2010 12:00 AM
98infinity
1997 - 2003 F150
07-24-2007 09:38 AM
sprinklerguy
1997 - 2003 F150
20
03-19-2007 10:57 PM
