Morning rough idle & code 542 again
My poor truck is acting up again. Rough morning idle and will stall out unless I hold the idle at 1000 til it warms up. After that the idle surges between 500 and 600.
Also in an earlier thread I researched a code 542 and found a bad breaker that appeared to fix the problem. Two weeks agao the fuel pump would not activate when the key was turned. I hit the tank 4-5 times with a 3 lb rubber hammer and it has ran since then. What does this indicate?
Here are the codes that were present.
KOEO
122 (O,M) TP low (possibly grounded or open circuit)
128(M)MAP vacuum has not been changing - check vacuum lines
334(O,R,M)EVP sensor is/was high
542 (O,M) Fuel pump open, bad ground or always on
KOER
312 (R) AIR not diverting
I cannot find a vacuum leak nor can I hear one. I do not understand the other codes.
Any help/advice would be appreciated. Thank you
KOEO
KOER
trippn4re
23
06-02-2014 05:16 PM
partsman01
08-27-2008 03:14 PM
