Still leaking water
Old 05-06-2017 | 01:48 PM
1993 ford's Avatar
1993 ford
Still leaking water
Hello I have posted a thread before about how I got water in the cab when it rains everybody said clean the cowl drains out I did that and cut the old seam seal out siliconed it let it dry and then flex sealed it and it still leaks when I put the water hose on top of the cowl. It looks like it is going in the square hole that is towards the engine on the passenger side of the truck. When the truck is warmed up and I run the water hose on it the water that leaks in is warm it is not antifreeze how can I fix this issue. Thanks
indebt
16
09-15-2010 02:10 PM
55 f350
19
07-22-2008 09:09 AM
enduringexplorer
04-08-2005 02:42 AM
lastchance
Appearance & Dress-Up
06-29-2004 01:40 AM
Quick Reply: Still leaking water
