Half of instrument cluster lighting up
It could be as simple as the little cluster lamp (most inboard) being burned out. If you have the composite material cluster-back, it could be crumbling away, and the bulb socket is no longer making good contact with the trace. I had the exact same issue with my 77, and it was the disintegrating cluster. I got one off eBay.
A good upgrade, assuming you have the good plastic cluster back, is a pair of cluster lamp LEDs. I got a set from O'Reilly today, and they made a big difference.
You only need two, one for each side of the speedometer
Here's a link: https://www.ford-trucks.com/forums/1...per-truck.html
Jghake
03-30-2018 11:36 AM
landers0440
06-24-2014 10:43 AM
Buyerz
03-02-2014 02:35 PM
