300 I6 in 1950 F6
Old 02-20-2017 | 06:16 PM
KK560's Avatar
KK560
300 I6 in 1950 F6
Is there a different bellhousing or adapter that will bolt the bellhousing of a 300 to a t98?
Old 02-25-2017 | 12:16 AM
85e150's Avatar
85e150
The T98 will have the old square pattern, and the 300 will have the rectangular "butterfly" pattern.
You could inspect the bell for the six and see if the transmission bearing retainer will fit into the hole in the bell. See if the top two or even one bolt hole matches up. Check the input shaft length.
Then it get's tricky. You may be able to drill holes to match the trans pattern. The question then would be is there enough material to thread into. Or could you put a bolt through from the back side and use it as a stud to hang the transmission.
Since the square pattern died as the 240/300 was born, I don't think you'll find a bell for the 240/300 with the old pattern.
An adapter would have to be fabricated and might interfere with the proper input shaft depth.
Old 02-25-2017 | 06:52 AM
KK560's Avatar
KK560
My T98 has 6 studs.
Old 02-25-2017 | 03:30 PM
85e150's Avatar
85e150
Interesting. I was going off info here:
https://www.novak-adapt.com/knowledg...ns/manual/t98/
6 bolts.....well, they wanted to make sure it wasn't going anywhere I reckon.
I found a bell with that pattern in of all places a Ditch Witch salvage site:
http://www.hceweb.com/used-trencher-...-machines.html
Does your current bell look like this?
http://www.ebay.com/itm/1930-1931-Mo...-/222420645238
Maybe more like:
http://www.ebay.com/itm/48-49-50-51-...-/142290017825
or
http://www.ebay.com/itm/1932-1952-Fo...-/322433960775
Old 02-25-2017 | 03:47 PM
85e150's Avatar
85e150
Back to the start: What is the intended use? You could probably get by with the "later model" current butterfly bell with matching T18 or NP435 transmission from a later model pickup. You might also find a 300/NP435 setup from an economy model F600.
Brian Piper
09-12-2014 04:35 PM
390Highboy
02-03-2007 06:38 PM
HT32BSX115
04-13-2006 01:39 AM
HT32BSX115
05-29-2005 01:52 AM
Chris56ford
04-23-2003 08:56 AM
