1977 F250 custom 4X4 7.3 IDI / 5 speed swap / build
#91
Spare tire carrier
At first I thought I might build a roof rack and put it up there... after throwing the tire up there that was a bit ridiculous...
I might still build a roof rack someday that would double like a headache rack for long Lumber or big ladders but the spare tire up there was just too much.
So I decided I would mount it underneath similar to a stock truck in the back.
There were several obstacles to overcome. One of the biggest of the tow hitch that my dad put in was right in the way so I had to cut it out and refabricate it to go around the tire.
The fact that I am using a military 37 for a spare did not help anything either. I put the tire on a stock 7 1/2 inch rim to gain all the ground clearance I could.
The next challenge was there is no room for the cable reel due to the gas tank. So I inverted it I put the cable reel on the tire and fabricated brackets off of the gas tank straps for the foot at the end of the cable to go into.
I got the spare tire cable reel out of a mid 2000's Dodge Ram 1500 the one with those huge 20 inch wheels it was one of the bigger cable reels I had seen while browsing the wrecking yard.
I've then fabricated a crank handle out of a 1929 Ford hand crank starter and a 1/2 inch Drive swivel. then mounted an old impact socket that didn't belong to a set to the cable reel.
I also used a couple quick clips to attach the reel to the spare wheel. At first I was not doing that but it proved to be very helpful it is already cumbersome enough when you're not having to fight to keep that cable reel in the lug nut holes.
It doesn't really hang down any farther than other spare tires that go in the back and it doubles as a gas tank skid plate hahaha
#93
Receiver hitch modifications
Way back in the early 80's when my dad first lifted this truck and put in the tow hitch he built this drop receiver.
It had a regular gusset in there but I cut it out and put this TMR customs bottle opener gusset in. Also the bottom plate where the ball mounted was slightly bent down so I decided to Beef It Up with a couple pieces of half inch stock.
I also added in a step to make it easier to climb in the bed. Let's face it I'm not getting any younger and I can't climb in and out of there like a monkey like I did when I was a kid.
I don't seem to have a picture of it but my dad also drilled a hole going top to bottom on the Square Tubing so that you can put the hitch in sideways so it parallels the bumper if you're off roading or whatever.
#95
#96
#97
Better tires
The tires I have on the truck for mach up are in pretty bad shape 2 are badly cracked and none have very high tread. The rims are also way to wide for the truck and the tires.
I can't complain got them for mach up on Craigslist 4 tires with rims and a 5th tire loose for $200 they served there purpose I kept the best one for my spare and was able to sell the 4 with rims for $150.
Browsing eBay I found 4 Goodyear 37's delivered for $380 from Arizona so I swooped on that and mounted them on the steel wheels my dad already had on the truck.
#98
Shocks and helper bags
I decided to switch all the shocks over to loop loop mount. Alot because I had a set of doeschtech shocks and because there seems to be more options for loop loop down the road.
The fronts I used the lower mount off the 88 F350 and just drilled the stock upper. All the original mounts are in place should I want to go back to the stock style shock.
On the rears I cut the perches off the rear end and moved them up so they don't hang below the axle tube don't need any rock grabbers hanging down. On the top I used a conversion bracket from fab tech I picked up locally.
The air bags are not ideal but I got them out of the Wrecking yard for $25.... Don't mind it being stretched out I have the suspension at full hang you can see the air jack in the back. I plan to get some double billow bags later but for now these will do for my move I have a 7000+lb camper and a 8000lb+ tractor load to haul 1000 miles north...
#99
Adding switches to the dash
Drilled the dash for all the rocker switches. Between the lights, air compressor, rear bags are going to be on solenoids.
I decided to put in seat warmers as well I put the rocker for that in the middle.
I did put in one extra Incase I add more lights or something later.
#102
Heater / A/C box rebuild
I had 2 heat a/c boxes from the Wrecking yard took the best from each.
Got a heater core from the local parts house. I made all new foam for the flaps from packaging foam. Just used the 3M 90 glue to put it on.
I insulated the under side of the box with frost king self adhesive duct insulation.
#105
That's an interesting take on the spare tire carrier - I have to look around at what I've got in the scrap pile now.... I was thinking about a modified stock carrier, with a winch out in the passenger rear corner to get the max. clearance, but maybe it isn't enough to worry about. Spare tires in the box suck, they're always in the way, even if you have a flatbed.
Where are you moving to?
