1977 F250 custom 4X4 7.3 IDI / 5 speed swap / build
#211
#212
Headlight / wiper *****
If you haven't noticed I kind of have a skull theme...
Made some headlight and wiper ***** out of some metal skull valve caps.
Drill a hole in the back for the rod, drill the hole some across the opening ( but not all the way through ) where the valve stem screws in so the shaft can bridge the hole. Re thread the valve stem hole for an Allen set screw and tighten it down on the shaft.
Good trick for any valve cap you might want to turn into a custom ****...
#215
#216
LED dome light
I had no dome light at all so I got the LED dome light kit from LMC I like it nice and bright.
Truck Parts and Truck Accessories
#218
#219
Lights!
I went all LED, I just put in 1157 LED conversion bulbs for the turn signals and tail lights.
194 LED conversions for the side markers.
I also used LED in the license lights I believe they were 1150's.
Keep in mind if you plan to go LED you either need the ones with built-in resistors or to run an electronic flasher.
I went the flasher route if you do this be sure to get two 1 for the turn signals and one for the hazards.
I used this flasher https://m.summitracing.com/parts/upd...Z30BoC0QTw_wcB
#221
#222
Rear air bags
Plumbing the air means doing the air bags also.
I put the bags on solenoids so I can inflate or deflate with a toggle from the dash.
Didn't get a good pic of the solenoids but they are mounted on top of the crossmember just below the bed floor so they are good and protected.
#224
#225
