Dash swap
Old 10-11-2016 | 10:21 PM
Josh Picard's Avatar
Josh Picard
Dash swap
I was wondering if you could fit the dash from a dentside into a bumpside and make it look decent? The two body styles use the same windshield, correct? I did some searching around and couldnt come up with anything. Thanks in advance
Old 10-11-2016 | 10:37 PM
ultraranger's Avatar
ultraranger
Are you talking about the dash pad or the entire dash structure and pad?
I've seen an entire Dentside dash structure/pad in a Bumpside so, I would think the opposite would be possible.
The Dentside dash structure bolts into those trucks. On the Bumps, they are spot welded into the cab.
With the Dentside dash swap, it would be nice to have the A/C ducts plumbed integral into the dash but, the Dentside gauges leaves a lot to be desired to me (compared to what you can do with the instruments/cluster in a Bumpside).
I'm not certain how easy it would be to swap aftermarket gauges into a Dentside instrument cluster (if a person wanted to do that) or, how good it would look if it is possible (?).
Old 10-12-2016 | 09:44 AM
Coastal68's Avatar
Coastal68
A few questions:
Are you experienced/talented with metal fabrication? This is one of those ideas that could work, but only if done with skill. I think we've all witnessed the horror of hacked up trucks. Sometimes what seemed like a good idea just ends up destroying what was a decent truck.
Why do you want to do this? The answer to this question helps determine the answer to the next.
Is the benefit worth all the bother? I have often thought of swapping '67 doors and dash ***** into my '68 'caus I like the look of them. However, the benefit would be worth far less than all the work, IMO.
Old 10-12-2016 | 01:56 PM
f100today's Avatar
f100today
Old 10-13-2016 | 07:38 AM
Josh Picard
ive never messed around much with sheet metal but i can weld and know the basics. does the entire 73-79 dash just bolt in? i thought part of them were welded. i didnt know the doors from a 67 were different from the 68
Old 10-13-2016 | 04:32 PM
JEFFFAFA's Avatar
JEFFFAFA
It was definitely NOT a bolt in. I suggest you check out his thread here. I believe he was doing the dash at approx. 1/2 way through the thread.
Edit. Start on his thread's page 19. Post #272.
1967 F-100 project ( 1 2 3 4 5 ... Last Page)
67nukeford
Old 10-17-2016 | 12:42 PM
67nukeford's Avatar
67nukeford
As the guys posted above, I'm doing this with my 67. It requires the removal of all of the spot welds along the bottom of the windshield to remove the 67 dash. I also had to graft the curved section of the 67 dash onto the forward section of the 79 dash, to get the proper curve to fit back on the windshield frame . Its not an easy project, by any means, and I probably would not have taken it on, if I wasn't already planning to pull the cowl.
Old 10-17-2016 | 12:43 PM
67nukeford's Avatar
67nukeford
The dash is a two piece on the 79. The front section is spot welded on, and the back section screws onto the forward piece.
Ducken331
01-31-2024 09:50 PM
77megacab
12-26-2017 06:32 AM
Hanoverfiste
1997 - 2003 F150
01-09-2008 09:53 PM
edward021070
16
03-02-2007 09:55 AM
wintremute
04-15-2006 12:06 AM
Quick Reply: Dash swap
