Need A Wiring Diagram: Ignition Noise Capacitor
The capacitor that is part of ignition circuit located on your points prevents arching across the points contacts. In most cases this is the source of and the solution to noise in the ignition. A capacitor is an AC device and is impervious to DC voltage. The case of a capacitor is grounded and the wire is connected to any leg of a circuit that may have an AC component that you wish to filter out. Since one side of the ignition coil is connected to ground via the ignition points, another capacitor could be added to the other pole of the coil to assist in filtering out AC noise.
Is that the standard Ford service manual? Mine for the 49 doesn't appear to have that section. Looks like the store of Yankee Ingenuity that I need.
Daugust32
28
08-03-2019 09:42 AM
Spooky Ol' Joe
13
12-20-2016 06:57 PM
4speedspring
05-24-2016 11:29 PM
03trueblue
09-24-2011 09:38 PM
ErrorS
13
06-19-2007 10:39 PM
