ELC Coolant in L99 7.3 ?
Many years ago I super flushed out the Ford Gold (I think) coolant out of my engine during a water pump change.
Mt truck is a L99.
I put in the Peak Final Charge ELC Coolant, and added the Diesel Site Coolant filter system.
I have incurred a coolant leak which I BELIEVE is coming from the gasket between the front cover and the engine block itself, though I have NOT had it pressure checked yet.
It IS possible that either my coolant temp sensor or heater hose fitting is whats leaking-just got to have the cooling system pressure checked.
I have read that some folks are experiencing coolant leaks caused by the ELC.....is it the E99s or all of them that experience this?
Suggestions? Thoughts? Thanks Guys!
Mt truck is a L99.
Mt truck is a L99.
Mt truck is a L99.
Was actually thinking about BUYING a cooling system pressure tester, but they are kind of expensive! for a possibly one time use...
Tricky
Coolant can be tricky because of the large fan on the front of the engine slinging it everywhere.
Weird coolant loss
then other issue is a hose was leaking by the power steering pump I am at a loss as to why I lost so much coolant I replaced the water and thermostat and serpentine belt
since I replaced the high prosser line I smell gear oil
