6.0L shifting back from overdrive to 1-st gear by 50 mls p/h
I did not check all the past postings, but did anyone had this weird problem with a '03 6.0L:
Driving down the road about 50 mls p/h and transmission downshifts from overdrive to 1-st gear .
From that point; when your start the engine idle is high (about 1.000 RPM) and won't drop; Tow/Haul light is flashing.
Will re-program (update) the computer help ??
A Dutch Ford Fan
A Dutch Ford Fan
We've found the problem. Disconect the electrical cooling fan, make sure al error codes are gone. Start the truck ....... if it runs normal, your cooling fan is ready for the scrapyard. Order a new one, mount it and ....... no more problems.
A Dutch Ford Fan (not from the cooling fan !)
remmers
10-21-2008 04:56 PM
Scott Fraser
05-13-2008 08:21 PM
