IAC questions
Old 11-04-2015 | 10:19 AM
canman47's Avatar
canman47
Trailering
IAC questions
Hi, I'm a new member with an 89 F250 5.8 I use for a work truck. Had an occasional high idle and took it to a shop who couldn't find a problem . They cleaned IAC, check timing, TPS, scoped and code checked it. Nothing wrong but I still got the sometimes high idle. I replaced the IAC and now it stalls on warm starts. Idles rough and high hydrocarbons on smog test. It did have a 33 code for EGR. I replaced the EGR and sensor but as far as I can tell the EGR never opens under any conditions. No vacuum ever to it. Tried another IAC with same result. When I remove it and energize it there is no plunger movement with 12 volts at the connector. Is that normal? Does engine have to actually be running for it to open?
rollnhvy
30
09-13-2007 05:23 AM
rpford
1997 - 2003 F150
01-03-2007 10:36 PM
cathcart72
1983 - 2012 Ranger & B-Series
05-17-2006 06:14 PM
guzzler96
13
03-19-2004 02:17 PM
netops
12-05-2003 02:24 PM
Quick Reply: IAC questions
