Windshield Wiper Motor Wiring
I am in need of some help with the windshield wiper motor wiring for my 1966 Ranchero. I finally found a new motor, it has 4 wires; red, blue, black, and white, plus a ground wire. The original wiring for the Ranchero motor has just three wires, no ground. I have installed the motor and done some testing with test leads. The motor works, is a 2 speed, the original was a single speed, I can deal with that. My quandary is the other wires and what they are for. In testing the motor whenever I shut the switch off, that is where the wipers stay, is that normal?
Any information will be greatly appreciated!!
<p>the other wires are for the second speed and washer. when switching from single speed to 2 speed you also need to swap the switch and wires. the 3 wires in the single speed are for hot, washer and park with case ground. the four wires in the 2 speed are for high, low, washer, park and the case is the ground.</p><p> </p>
bryanmartin
05-17-2016 11:48 PM
53ford
05-08-2009 12:05 PM
r_reed
04-16-2008 08:16 AM
Gary Kristiansen
08-19-1999 11:32 AM
