92 Ford F-150
92 Ford F-150
Hey back here again!
I had some good help last time and really enjoy this site and the people here!
I have a a question about a few codes and what to diagnose. Code 172 HEGO (HO2S) Sensor Fault/Lean. I have a 1992 Ford F-150 5.0 (302) 4x4 with two tanks. Does this truck only have one O2 Sensor? Or more? Also I'm getting a Code 411 Cannot Control RPM During KOER Test, Low RPM Check. Also it has a exhaust manifold leak on both sides there's a crack. I did put JB Weld on them so sounds a little quieter but still kinda loud.
So change out the throttle position sensor? Is that for the 411 code? I'll check the ECU as well. What would I be checking for and how? To be honest I just bought the truck for $750 and it has 140,xxx miles on it and the transmission was rebuilt a year ago from wat I was told. It has new water pump and new oil & filter so far and air filter and a overdrive button because it didn't work. About to do a tune up soon. So I'll have to just change out the O2 Sensor then. Would it be smart to do it after the exhaust manifolds are replaced or is it ok to do it now? Thank you for you answer Puddy! I appreciate it!
Manifolds firs then see where you are at, sometimes these issues can work hand and hand with each other. That's just my two cents.
Legal Lariat
11-01-2015 10:28 PM
stlouis
01-26-2015 02:04 PM
