Coolant flush after oil cooler replace?
Old 03-28-2015 | 01:53 PM
f150crewcab's Avatar
f150crewcab
I just had my oil cooler and EGR cooler replaced, and I'm now consider doing a coolant flush with Restore/Restore+ to ensure the coolant system is clean. I know this might be backwards and perhaps should have done the flush first, but schedule and such did not allow. I do have a coolant filter. Thoughts?
Old 03-28-2015 | 02:09 PM
69cj's Avatar
69cj
I personally would not. As you stated the flush should have been first. Now you would risk breaking stuff loose and plugging the new cooler. If you now have the proper coolant and ratio I would call it good and keep an eye on the filter.
Old 03-28-2015 | 07:22 PM
LivingLarge's Avatar
LivingLarge
X2, don't flush now.
Old 03-28-2015 | 07:49 PM
87crewdually's Avatar
87crewdually
You missed the boat. You should of done a flush before changing the cooler. If you do a flush now expect to change your cooler again. All the junk is going to go straight to your new cooler clogging it up.
Old 03-29-2015 | 09:44 AM
05F250DSL's Avatar
05F250DSL
If I were to do anything it would be pull the block drain plugs and let that just run out then drain the radiator and add a coolant filter. You could just pour distilled water thru until is clear from the block and radiator drains. But as mentioned I would not do any kind of chemical our pressurized flush.
Old 03-29-2015 | 12:48 PM
f150crewcab
Great advice all. Thanks!
green_95
07-05-2019 03:07 PM
Bodo Malo
10-22-2018 01:36 AM
surfmanrescue
12-29-2012 04:11 AM
firedaniel
07-31-2011 07:33 PM
Heckler
09-16-2010 12:49 PM
