Winch for F-350
#31
#32
Wholesale Batteries if you have one nearby is a good source. They have #2 lugs with a 1/4 hole. For crimping I use a hammer crimp setup that I also found there. Like this from ebay.
Per 462 Battery Wire Cable End Terminal Lug Impact Hammer Crimp Tool 8 4 0 AWG | eBay
You will want to fuse that connection. As close to the battery as possible.
#34
its confusing at best. Take the hitch that I put on the front of my truck. Its rated at 500 tonge and 9000lbs straight line pull. what does that mean. on flat ground I can push a car in neutral while barefoot...how many pounds of straght line pull is that.....is 9000lbs needed to pull a train and a couple of train cars.
if I have a 12000lb hitch and a 12000lb winch, can I drag 4 3000 blocks of cement down the street?
does pulling my 7000lb truck which have wheels require the same straight line pull as pulling my 7000lb truck if I take the wheels off?
If I put a support bar on my hitch and connect to each of my tow links, does that give me 27000lbs of straight line pull. what can I pull with that?
Can you increase your pulling power? Yes, by adding a pulley(s) to multiple the force.
You may want to read thru this:
http://www.of4wd.com/pdf/WARN_Guide_...e_Winching.pdf
I have a Warn PowerPlant 12 k on the front of my truck. I like this unit as it has an integrated Air Compressor. I have had it since before they were released to the public (I did some hot weather testing on it). It been on 3 Jeeps and 3 F 350's, works as good today as it did years ago. Not cheap by any means but it performs and the air can power an air tool, fill up a tire etc. I have used it a LOT, extracted people, filled flat spare tires for folks sitting on the side of the road.
You can find one used on ebay for about $900 bucks...
#35
I know this is about 9 months old, but I have seen far older brought back from the deep web. I am 99% sure I ma going with the Warn semi-hidden option for my truck.
Warn Industries - Mounting Systems: WARN Hidden Kit
And the Smittybilt 12,000 lb winch permanently mounted behind my factory bumper.
http://www.ebay.com/itm/181982672716?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The bumper mod is around 670.00 and the winch as right at 500.00. So not to bad for a good system and a well built winch. I do need a skirting kit with this bumper setup. But still way cheaper than buying a new bumper. Besides, I don't link the appearance of the current crop of after market bumpers.
B.
B.
#37
Just FYI - For most batteries with top and side posts, the side posts are inferior and use a thinner metal strap to connect to the plates inside the battery housing. A high amperage draw like a large winch has been known to burn these connecting straps up.
#38
But they're good enough to start a sissy little Chevy..
#39
Siriustoo
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
01-23-2017 01:27 PM
MR5x5
03-22-2009 05:43 PM
