302-351w headers that fit gt40p heads?
Old 01-31-2015 | 06:02 PM
1976fordguy's Avatar
1976fordguy
Just wondering if anyone has installed gt40p heads In a 73-79 truck? If so what headers worked??? I have a 76 f100 shortbed that I am installing a 1996 351w 5.8 motor in and I am about to purchase a set of gt40p heads that are all rebuilt instead of running the stockers. I know there is spark plug angle issues and all of that just figured I'd ask to see what people have found out.
I looked into these but am not sure if they work with the plugs and my body style.
Also I'd prefer to run long tubes for the torque.
http://m.summitracing.com/parts/big-12500flt/none/images
Thanks again!
Old 01-31-2015 | 09:28 PM
1976fordguy
Headers
Bump!!! Anyone would be greatly appreciated! Ones that don't work or do!
Thanks again
-Scott
Old 01-31-2015 | 10:11 PM
HIO Silver's Avatar
HIO Silver
Dunno man... you may wanna PM ultraranger. He's down with the 5.0.
What about these?: Ford Racing Mustang Shorty Headers M-9430-P50 (79-93 5.0L) - Free Shipping
Google "gt40P headers" and quite a few links pop up.
Sanderson has some shorties too: GT40P Headers
Old 02-01-2015 | 12:35 AM
blue04.5's Avatar
blue04.5
Yes, I did. Standard summit brand(reboxed flowtechs I believe) for these trucks with a 302. You have to clearance the header flange for access to the sparkplugs. Also you will need to run a 90 degree sparkplug boot on the #5 cylinder. The driverside header will have to be loosened and pulled aside to get the #5 plug out because the tube hugs the head in that area. Like I said this was on a 302 I know the 351 is slightly taller and a bit wider.
Where are you located? Shipping would be a pain, but if you are close, the ones I had are garage ornaments at the moment.
Old 02-01-2015 | 07:32 AM
1976fordguy
I'm in CT and why did you end up pulling the headers after all? And for clarification also how close will the 90 degree boot be to the header? Is it something that will burn or I will have to heat wrap?
Old 02-01-2015 | 07:41 AM
1976fordguy
Thanks yeah those sandersons look like they will work nicely even though they are shortys but atleast they will clear
Thanks Scott
Old 02-01-2015 | 09:56 AM
blue04.5's Avatar
blue04.5
I pulled them because I have Trick flow aluminum heads and bigger headers now. Ah yes, CT, almost as far away as you can get while staying in the lower 48
Oh and no never burned or had issues with the sparkplug wires. No heat wrap either.
Old 02-02-2015 | 06:17 PM
1976fordguy
Haha yes that would be quite the ship for a set of headers. No worries I think I am going to wait on heads right now and pick up a set of aluminums in the future vs buying one set and knowing I will be getting different ones at a later time... Any suggestions? what trick flows are you running and how do you like them?
-Scott
Old 02-02-2015 | 09:36 PM
blue04.5's Avatar
blue04.5
I have a set of fast as cast 190 trick flow heads. I really like them. The down side is its time for a new clutch, the stock replacement I put in last year is not up to the task. With a 351 me personally I wouldn't look at anything smaller than a twisted wedge 205 head, although I have heard the new 190 11R heads are pretty nice.
Its kind of funny how I went from small heads and a dual plane intake to bigger heads and the biggest out of the box intake available for a 302 based motor and I picked up power down low from my previous set up and by far and away more power higher in the rpms.
Shoot me a PM if you like, I'll point you in the direction for tons of information on sbf's.
Qualityfire
02-27-2017 07:05 PM
Irokmonster61
03-24-2009 07:32 AM
bbf150
02-13-2006 01:01 AM
03stang
03-30-2004 10:34 PM
jrocco
10-18-2001 10:15 AM
Quick Reply: 302-351w headers that fit gt40p heads?
