Jolly Green Giant...2015 F-350 KR DRW
Six of them..... Two of them each have one moon.......
True confession time: With my last two trucks, 2014 F350 and the 2017 F450 I have currently, I purchased full maintenance agreements. I take it in to the Quick Lane at my Ford dealership every 5K miles and they take care of the rest, including topping off DEF. The only time I need to add DEF myself is when we are towing and the truck goes through it a lot faster.
By the way, I have a question regarding the Continental HSR 19.5's on my F450. I just had to replace the fronts at about 40K and I was a bit surprised by that. The rears still look almost like new, but the shoulders on the fronts were worn down enough that they told me they could not balance them and I was starting to get a little vibration at around 55 mph. Any thoughts out there in truck land?
Good luck.
EDIT: PS. This is the same as I did on the big trucks too, and I was consistently getting over 100,000 on a set of steer tires that way.
Thanks, I thought about doing just that. Part of the reason I didn't go that way is the wheels. The inner wheels on the rear are steel. Outers are polished aluminum, like the fronts, but the aluminum wheels only appear to be polished on the outward facing side. In other words, you'd have to unmount and remount all six to rotate them.
Ford puts the HSR on all six tire positions. In theory, Continental calls it a "steering axle" tread design. Continental also makes the HDR for drive axles to go with it, but Ford doesn't use it. I'm not sure why not.
You are so right about the HSR's following road seams and ruts. I had almost forgotten how bad that tendency is when they are new until I just replaced them. In my experience, it gets better after 5K or so, but never completely goes away. I will be interested to hear what you end up with and how they work out.
Hello, Steve. On the rotating tires and duallies; all I ever do is just swap the steer tires side to side every 7500 miles. On both of my Ford DRW (F350’s) with 17” wheels, that seemed to keep them wearing evenly. The ‘16 was bumping 60,000 miles and looked like they had another 10,000 in them. Now, on my brand X truck that I am driving now, I probably won’t get that kind of mileage out of them from all appearances at this time. As far as rotating the rears on a dually, I have found it to be a lot of work for little gain.
Good luck.
Good luck.
I don't know if anyone else has this issue, but thought I'd pass it along.
https://www.bbwheelsonline.com/toyo-...86eb84a7f71890
I want to share a "find" that I made today with all you folks that enjoy working on RV's. I was trying to replace a couple of rocker switches in our DRV with lighted rocker switches so that I could easily see if they are on or not. However, I was trying to find lighted rocker switches that would be direct replacements for the switches in the rig now so that they would cover the cutout holes correctly. (I think they make the cutouts in the panel with a chain saw.)
I was able to find the name of the manufacturer of the existing switches and that is American Technology Components in Elkhart, IN. On their website I found the exact switch I wanted and sent them an email. They immediately responded that I had the correct switch but that they only sell in cases of 300. However, they directed me to PDX RV Wholesale as a dealer that I could buy small quantities from. When I went to their website I was amazed to find that they carry EVERYTHING we have all looked for for our RV's.
Roy, if you really want to get into RV repair, you need this website. Here is the link: https://pdxrvwholesale.com
Thank You kind Sir.....
When you switch the steer tires from side to side, do you break them down to turn the same way or just switch them from side to side? Didn't think you could put them on the other side and turn the other way on the road. That's why front to back?
You are entirely welcome! I am guessing many folks already knew about this site, but it was totally new to me. I can't imagine how many things I may need in the future that they have on here. And prices seem to be reasonable as well.
Personally if I go the dually route I'd want steel wheels just for the ability to rotate them. On our customers duallys we rotate front to rear inner, rear inner to outer, rear outer to front.
I've had dually's as daily drivers since 2008 with aluminum rims outside and steel rims inside and unless changing tires on rims and balancing them is free for life it's cheaper to just swap side to side with the price cost vs tire cost. Front tires always wear faster being pushed forward by the duallys in turns.
Going in today for 6 new tires on the '16' the oem BF Goodrich Rugged Trail T/A didn't last that great with only 45,000 miles, 2/3 towing the 5th wheel. Going to try Goodyear Wrangler A/T Adventure with Kevlar this time. Price for 6 mounted, balanced, disposal of old tires ($4.50 each) with 6.5% tax is $1,700 which was slightly cheaper than the oem tires. The price to pay for wide hips on a truck.
