BOGGERS OR SUPER SWAMPERS
Sean, Boggers ARE Super Swampers. Super Swamper is just a brand name put out by Interco.
I am guessing you are talking about the difference between Swamper TSLs (the "classic" Swamper) and Swamper Boggers.
Keep in mind, most of what I am going to say is simply relayed from experiences I've heard about. Which is better depends on what kind of off roading you so. The TSL is a better all around tire than the bogger. It's quieter on the street (if that matters), rides better, and wears longer. It will also handle better in the snow and rain.
You'll find it tough to beat a Bogger in the mud or many other off-road situations that don't require too much lateral traction. If you run Boggers, your engine had better have the stones to turn them.
i have 38.5x14.5x16.5 tsl sx on my 78 they are great in the mud but not so great on wet pavement because there are no sip's cut into them thats the same with the bogger and the original tsl they will wear quick because they are designed more for offroad then on road because of the compound i would say try the tsl ssr if you want to stick to the intreco brand (tsl) because they where made for on and offroad use they have sip's which are better for wet suface's and they are still great for offroad and its a radial tire hope this helps you out
bad 78 f 250
bad 78 f 250
boggers as well as all super swampers are bias tires. Their rubber compound is very soft, and they are not suitable for the road. I would sooner go with a BFG MT rather than super swampers, but if you like you could go with the new 49" Super swampers out just recently.
Gear619
15
03-12-2015 07:08 PM
