Late 2004 Crank No Start
Have you tried unseating and reseating the FICM plugs? If not, take the opportunity to GENTLY tug on each of the wires feeding each of the three plugs when you unplug it again, just to verify that you've got no movement. It would also be a good time to ensure that no pins got bent in the module during install.
If previous posters are correct, your icp voltage appears to be doing strange things. I have not double checked those voltages to see. However, with the icp unplugged it still doesn't start.
So, verify your icpv koeo and during start. Post the pressure too.
I am leaning to the ipr or the hpop .... because it's a late 2004. Pull ipr and inspect, then do an air test and see it the air comes from the hpop.
Hpop not bad to change after pulling turbo.
Late 04s have the old hpop and do not have the stc fitting. You also don't hear of DP and SP problems with the late 04, but they do have them. Maybe the hpop fail too often and hide the DP and DP issue.
HPOP PSI 900-1000
I removed the FICM this morning and double check the connection and wiring everything seems good. I have pulled the batteries, I'm going to take them to get load tested. I'm hoping there bad and that is the problem. I will update later today.
ICPV are consistent KOEO .2 Cranking 1.6
HPOP PSI 900-1000
HPOP PSI 900-1000
You've checked all fuses, etc? Understanding that you have proper FICM voltage and you hear the injectors buzzing KOEO, it's still worth unseating and reseating the FICM relay under hood by the driver side hinge, doing the same with the 10 amp logic fuse that is right there, and doing the same with the likely 50 amp FICM (sometimes marked as an IDM) fuse under the dash or under the hood (check your owners manual for exact location).
Keep us posted!
Am I mistaken?
First off I would like to think everyone for there guidance and assistance.
Went to Ford and had the batteries test. One tested with a bad cell the other needed charged and retested. I choose to replace both didn't what to chance it. Funny thing is they would charge and read 12.9v. And usually the charger I use will let me know when a battery is bad. It never did.
Install them in the truck and it fired right up with out any hesitation. I glad I consultant the experts on this web site before throwing a bunch of parts and money at the truck. With everyone help and the Torque app (which I would recommend) providing all the information y'all requested we got it fixed.
Now the hard part, wife suggested replacing them at first. I guess I'll tell her what fixed it she going to find out anyway.
Thank again to everyone!
Just tell the wife, because she is obviously so good at it, she gets to fix it next time.
Hmm...I thought that the late build 2004 1/2 used the problematic dummy plugs and standpipes, had an aluminum hpop cover with cast iron hpop, had the icp sensor in the right valve cover and used the stc fitting - essentially exactly like the 05 and up models.
Am I mistaken?
Am I mistaken?
The late 04s do have the SP and DP, but you rarely hear of them failing in this model.
Regardless, glad you're up and running!
Thanks I glad as well.
