Home Brewed 70 Short Bed Build
#662
#663
#664
#665
Not many of us old 4 wheelers around.
Ah your never to old to pizz away money and have a little fun doing it a long with getting your hands all dirty & greases while tinkering as old farts need something to keep us busy as you move into the golden yrs.
Orich
#666
Welcome to the FTE Bump Kingdom.
Orich
Orich
#667
I finally got started on some of the body work on the Mustang, I knew There was some rust around the back glass and found it was worse they I thought, but all the inter frame work is good just some surface rust.
After cutting lots of spot weld I got the old panel out, then cleaned it up and primed.
New panel in place and plug welded.
Next starting on a door I pulled off of a parts car.
#671
Thanks GaryKip
Hay, I might need you to come help on mine. All joking aside the car was rebuilt in the mid 90's and garage keep after that. The quarter's, torque box's and cowl area was all replaced then and are still in good shape.
Thanks Gavin
I've started on the drivers door, the one on the car had some pin holes on the bottom inside of the door, so I decided to use one off one of the parts cars. It had some surface rust, and a dent but no holes. It's close to being ready for epoxy.
Thanks Gavin
#673
It's kind of naked all right, I hope to get time this week to get the other one the same way. While I have them off and still striped down I'm batting the idea around of shaving the door handles. I bought everything to do it on the truck, then decided not to. Anyway lots of ideas rolling around in this old head.
#674
I got the interior pulled out of the Mustang, then got into some more rust repair. I knew the rain gutter was rusty at the A-pillar, but it was worse then I thought, and the one on the parts car that I'm stripping was just as bad. So I decided to shave the gutters. I have a little more to do on the passenger side I will finish tomorrow, they start the drivers side.
This is the bottom of the gutter at the A-Pillar after I got the weather stripping off and cleaned up.
I cut the gutter about every 6" and removed the gutter between every other cut, I welded that then cut out the remaining pieces and finished welding. The roof is put together the same way our trucks are, you have three layers of metal at the gutter.
I still have a little more grinding to do, but this side is almost ready for filler and smoothing.
