6.0 question
Old 03-08-2014 | 05:18 PM
9228.bobcat's Avatar
9228.bobcat
Originally Posted by Paul Hicks
Ok, pretty much my last question I think, putting the head back on and noticed two dowels on the front and back of the cylinder head, not the block, curious as to what these are for? and how am I torquing the head with these on, any help???
The dowels just came out of the block. You should have new dowels with your gaskets. Take out the ones in the heads and put the new ones in the block.
  #32
Old 03-23-2014 | 11:41 AM
Paul Hicks's Avatar
Paul Hicks
I would appreciate any help on my turbo question, please feel free to give me a call if that is easier for anyone. Send me a message and I will send you my number. Thanks again for all the help. Turbo is bolted down, exhaust coming from manifold is at least a 1/2" short. Have unbolted the exhaust coming from the manifold. I am afraid if I force it I am looking for problems down the road.
  #33
Old 03-23-2014 | 12:18 PM
AKPOWERSTROKE's Avatar
AKPOWERSTROKE
Did you do an EGR delete with a new up pipe. Is that the side that is short?
  #34
Old 03-23-2014 | 12:21 PM
AKPOWERSTROKE
Are you able to post a pic where it's short
  #35
Old 03-23-2014 | 01:02 PM
Paul Hicks's Avatar
Paul Hicks
OK, I did not go with the delete kit, went with a filter upgrade instead. I wound up taking the turbo off the mounts, put the clamp on, then got the turbo over the oil tube and pushed down, the back mounting bolt was off, so I drew the turbo into the back bolt hole with the other 2 mounting bolts. I guess i am more worried that it may stress something. I was thinking it was short due to the expansion/contraction. It has been down since January. Bottom line is it is in place and bolted down. Again I appreciate the help and I hope to continue to learn and benefit from all of the experience out there. Thanks again.
  #36
Old 03-23-2014 | 01:13 PM
AKPOWERSTROKE
A 1/2 inch is a lot for expansion. I can see a few thousands of an inch. Everyone I have done mine the exhaust manifolds and up pipes were bolted in first then I installed the turbo. Takes a little finess to maneuver into place but it goes well.
  #37
Old 03-23-2014 | 01:38 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Sometimes a donut crush gasket is needed on the manifold to y-pipe.
Josh
  #38
Old 03-26-2014 | 02:23 PM
Paul Hicks's Avatar
Paul Hicks
6.0 question
Have everything done, put fuel in the fuel filter and have checked everything. Ford dealership said all I have to do is cycle the key numerous times and then start. Is this true? How long should I cycle the key, and what if it does not start? I know the last one is a biggie, just trying to think ahead.
  #39
Old 03-26-2014 | 06:20 PM
steelhead2's Avatar
steelhead2
Cycle the key 3 or 4 times on and off. It may take some cranking since you were pretty deep into it.it'll start, have faith!. Just dont get discouraged if you have to put your batteries on a charger overnight after you try the first time. The can be a real bear at times.
  #40
Old 03-26-2014 | 08:02 PM
olfordsnstone's Avatar
olfordsnstone
I seem to recall that there is supposed to be a delay in the on position. Maybe 5 seconds, I think? That's what I do after fuel filter changes anyhow, turn key on for 5 seconds, turn off, then back on for 5 seconds etc for 5 cycles. Maybe overkill but personally I worry about low fuel pressure at the injectors. I'm probably a little **** about it though.
  #41
Old 03-26-2014 | 10:02 PM
Mr.Nobody's Avatar
Mr.Nobody
Wow, we have an engine rebuild thread and no pics.... Amazing. Stealth rebuild! Yes cycle the key, but it is going to take a little bit to get oil pressure up to start, so when you start cranking it will feel like an eternity. Did you fill oil into the HPOP reservoir? I have heard guys talking about it taking "for ever" to get started after this type of work, because the LPOP has to fill that reservoir under the oil cooler.
  #42
Old 03-27-2014 | 04:30 AM
npccpartsman's Avatar
npccpartsman
The fuel pump will run for 20-30 seconds with each KOEO. You should do that 3 to 4 times after a filter change. You have a fuel pressure gauge, don't you Tim?
lupuseven
11-26-2012 07:38 AM
Canadianpowerstroke
10-14-2012 06:49 PM
TreeTech
12-27-2007 11:01 AM
desygityaso
07-17-2007 08:15 AM
Quick Reply: 6.0 question
