Coolant Flush After Injector Cup Replacement
Old 01-24-2014 | 08:50 PM
kush1972's Avatar
kush1972
Hello, So I found some diesel in the coolant and brought to my mechanic to check the injector cups. He found a pin hole in one of the cups. I had him replace all the cups while he was in there. I am still getting some fuel in the coolant and I am wondering if its normal to have some residual fuel left in coolant loop. Does anyone have any recommendations on flushing the system or should I just stick to standard radiator spill and fill. Thanks for your time.
Old 01-24-2014 | 10:31 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
I did mine in the summer, so no worries of freezing. I ran some dishwasher detergent it it for a few days and then drain and fill with water for a week or two.
Different story if you have to worry about freezing.
Old 01-25-2014 | 12:13 AM
Stewart_H's Avatar
Stewart_H
Moved to the 7.3L PSD forum.
Stewart
Old 01-25-2014 | 12:35 AM
crop harvester's Avatar
crop harvester
clean & monitor or pull injectors & pressure test,is the options Ive learned here.
Old 01-25-2014 | 07:27 AM
Tugly's Avatar
Tugly
I cleaned and monitored my coolant - the fuel came back. I pulled the injectors, drained the coolant, sprayed silicone in the cups, and pressurized the cooling system with 15 PSI of air (less than 15 PSI didn't show anything):
ExPACamper
07-04-2015 10:36 AM
zeppelingto
12-13-2012 12:33 PM
Brett W 55 Ford
11-21-2010 12:08 AM
jim fowler
09-17-2009 11:39 PM
bigdummyford
03-25-2009 10:46 PM
