If you ever replace your ECT sensor....
You may have to modify a 21 mm socket to get the damn thing out. I don't know how everybody else does it, unless you have an offset 21 mm wrench maybe. I ended up having to MacGyver a deepwell socket to get the sensor out...there's not much room. The old sensor was nasty.
I have a couple modified sockets. One is cutdown for access to the serpentine tensioner on Ford 3.8 FWD engine. Until I realized you could just pull the belt by hand no problem. Oops.
Another is an SK 3/4" drive 1 7/16" impact socket I had to whittle down on a lathe to fit the rear sprocket bolts on a Deere 750C crawler.
Not too happy having to do that.
Josh
Jesser02EX
06-21-2013 05:56 PM
navigatorstang
02-17-2011 08:14 AM
