2000 Ford Expedition Blend Door Project- Need Help
I'm trying to remove the blend door actuator so I can continue trouble shooting. Problem is, there's a floor duct in the way. I've removed the two bolts holding it, but I cannot get it out. How do I remove this thing without cutting the carpet and floor duct?
Also, before I get any further into this project I want to throw out the symptoms this has to make sure it's actually the blend door.
Here's what it does. A/C works great. Heat works not so great and only on the two lowest fan settings. When the fan is turned on high, it blows cold air.
Blend door motor turns in response to the rheostat. No plastic shavings were found on top of the actuator when I pulled it down. Is there anything else that could cause the heat to not work well?
I HAVE HEAT AGAIN!!!!!! I replaced the thermostat, blend door, heater core and the actuator. The blend door was fine, no cracks present so I'm thinking heater core or actuator (though the actuator turned fine, maybe weak?) I still need to assemble the trim and I have a pretty bad coolant leak at the thermostat housing, so I'll need to take that apart again. I replaced the O-ring, so not sure what the problem is there.
I'm really glad to have it working again. Whoever the engineer was that designed this and the floor vent leading to the rear can go to H*LL!!!!! What a p.o.s. design.
No valve to the heater core. The heater core is "on" all the time. The blend door blocks the hot side when calling for A/C and blocks the cold air side when calling for heat and swings back and forth to "blend" the two to get the desired temp.
2003 Ford Expedition
Anyone have input for me. I have heat in the front. Air conditioning doesn't really get cold in front. The rear gets air conditioning gets really cold but I don't get heat in the rear. I hear a popping in the rear blend door. Can this rear blend door cause the issue with the front getting cold?
husky390
11-04-2013 10:20 AM
