Wheel/Tire and Lift Questions, 2000 F250
Just got a new to me 2000 F250 CCSB 4x4 and I want to do a few things to it, looking for advice from those that have already done this and know the right combination of offset, backspacing and lift.
It has a 4" shackle and block lift right now with about 35" tires that rub the leafs before full lock. I want to get rid of the lift, I just want stock height, but level. What are my options to do this? If I put it back to stock, will it be level or would I need 2" shackles for the front or what?
I also want to get smaller tires, I think I want 17x9 wheels and 285/70-17 tires. What would the proper offset and backspacing be? I'd prefer to have them flush with the wheel wells and I'd rather have them stick out a bit than be inside the wheel well too much.
I'm looking at this wheel, how will it look with 0 offset? Any pictures of similar size wheels/tires with this offset?
Thanks!
Thanks!
I think I have the wheel/tire combo figured out, now on to the suspension.
I want the truck at about stock height and level. How do I accomplish this on the front? Right now I think there is just a shackle/hanger lift which is probably 4", what parts do I need for just a good 2" front lift?
When I was under the truck I checked out the rear, I couldn't believe how they lifted it... I figured a 4" block, but no, there were two blocks stacked!! I don't know if this is normal, but I would never do it myself. I guess it makes it easier for me now though, just remove one block and it should be stock height in the rear I assume.
So, what say you? What are my options for the front, what about the trac bar, how do I know what parts are stock and what has been changed?
