94 7.3L idi turbo diesel. looking into ATS, Hypermax, or Banks Turbo kits?
Hey there guys its been awhile since I last been on here...but would be glad if you guys could give me some good feed back?
Well first of all I know these trucks weren't intended to make all that much power. With that being said I myself have a factory turbocharged idi. My question to you guys is if by upgrading to any of the 3 turbo kits listed, would improve anything on my truck?
I would jus like to add some kick to it. She has a 4in. Exhaust system from Diamond Eye performance, Also a K&N air filter.
Any suggestions would help . I hope I made some kind of sense to you guys lol.
I'm almost positive the downpipe I got with the 4in. Turbo back exhaust system. Now the elbow I am unsure of to be honest with you? Where about is this elbow located and where could I buy one?
The down pipe connects to the elbow which is roughly 2.375" You dont buy it, you modify it. the elbow is on the exhaust housing. It necks down from 3" to the small size, you just cut it back to where the 3" is and weld on a 3" marmon flange.
After that, studs, IC, and pump / sticks will give you more.
The turbo itself can get upgraded wheels if the exhaust housing is machined. Contact Russ (Type4) above, or Justin (R&D IDI Performance). The 3" elbow is great, except good luck finding one... You can't get the stock elbow either. Believe me, I've tried. But don't be discouraged. At stock IP fuel levels, most of your gain will come from removing the crushed factory down pipe if it has not been done already, eliminating exhaust leaks and intake leaks ( if any) and replacing the horrible factory air box with a good, free flowing cold air intake and aftermarket filter. Do you have a boost gage? Pyrometer? What are you seeing right now? You can squeeze a bit more out of the factory unit with wastegate adjustment, but you really need to have gages.
Oh ok I got ya. Sorry bud lol.
-intercooler would be sweet! What application would work best in my situation?
-I am unaware of the injectors. I know I've replaced I believe like two and purchased them at auto zone . I believe they were Delphi's. Is there performance sticks sold else where?
Oh btw I forgot to mention that the IP on my truck is turned up a bit. Joker smokes like crazy if I get on it.
If you want an intercooler, get one off a late 7.3 Super Duty or a 6.0 Super Duty. They'll fit, but both require modding.
Just my advice, but if 1 or 2 of the injectors needed replacing, then the rest aren't too far behind it. The old IDI diesels aren't like Powerstrokes where the injectors can last for 2-300k miles.
There's no such thing as "specific horsepower adding" injectors for an IDI. And only one company I know of that actually makes performance injectors, and those are designed specifically for his custom performance pump... place called Conestoga. I don't know if R+D does injectors. They both do injection pumps. TypeFour can do injectors and upgrade turbos.
One last thing... get a pyro on that truck.
Well to be honest with you I haven't installed any gauges. And I believe we shortened the waste gate rod a tad bit awhile back jus for ****s and giggles but it wasn't much of an adhusment . Just a slight tweak. Now my truck is equipped with a zf5 speed...I could do without the transmission guage, correct? If so, I would jus need egt gauge , boost gauge and?
