electrical problem
electrical problem
electric dummy here I have a 1972 f100 and received the truck not running . I have no power to anything under the dash including the ignition switch . I have power to the one side if the starter solenid that the battery cable connects to. The question I have should I have power on the I post? Is that what supplies power to under dash?
no. if you have no power into the cab you have either a blown fuse or broke/missing connection. You should have the main + battery cable connected with 3 other wires on the same terminal large terminal. one wire from the ignition to a small post. The large starter wire on the other large terminal by itself. the power for the cab comes off the post the battery is connected to. Start there, and check the wires.
Cab power is supplied by a black wire with a yellow trace on the hot side of the solenoid. Check Mr. Fusible Link!
You have a multimeter, right? There is no excuse to not have one.. Harbor Freight has coupon for free ones with like a $20 purchase. I've got five of them... one in each work area, one in a troubleshooter box, one in an electrical tool box, and one in the junkyard toolbox.
Yep. There's your problem. Find a harness from a donor truck at a local wrecking yard or make one up. Make sure you incorporate fusable links. Available aftermarket or from Ford. I believe they are 18 gauge.
Doin' this from memory but I'm thinkin a yellow wire with a red trace goes to the horn(s)... that's why it doesn't show on the diagram above which is specifically for ignition, starting, charging, & gauges.
