Plastic collar for shifter in column??
Old 05-08-2013 | 06:43 PM
stp1971's Avatar
stp1971
NumberDummy Rules!!! Just want to say Thank You VERY much for your help!! You are a valued asset to the Ford Truck community!!
BTW... I'll be looking into becoming a supporting member of FTE and getting my t-shirt also!! The help on this forum is well worth it!!
Old 05-29-2013 | 10:39 PM
stp1971's Avatar
stp1971
Leroy the Brown '78 is on the road again!!
So finally got the steering column and the 3 speed shifter on the column finished. Complete rebuild. Shifts a lot better and even steed better too. Did make two 1/4 turns (1/2 turn total) on the gearbox. Took a lot of the slack out of the steering. So now Leroy the brown truck is able to move again
Thank You to NumberDummy and anyone else who has helped get the old truck up and running again.
Old 06-13-2013 | 02:29 PM
shabazz18's Avatar
shabazz18
Don't bother, the bushing is obsolete. I sent you the part number/sources via email.
Can you please list those parts sources? Thank you.
05-X
02-14-2012 07:15 PM
wesmansr
01-19-2009 08:35 AM
sealer187
07-30-2008 10:09 PM
tylerbrowntyler
06-14-2008 09:38 PM
Quick Reply: Plastic collar for shifter in column??
