Proper ICP Volts?
Old 04-16-2013 | 08:51 PM
Roasted7's Avatar
Roasted7
Proper ICP Volts?
I just had a P2287 code pop up today. I was kind of surprised because I haven't noticed any running problems.
I want to monitor my ICP voltage but I don't know what it's supposed to be. Any help is much appreciated.
Old 04-16-2013 | 08:53 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Old 04-16-2013 | 09:10 PM
Roasted7's Avatar
Roasted7
Thanks Bullitt390! Just what I was looking for.
Any idea what is considered acceptable deviation?
Old 04-16-2013 | 09:24 PM
Bullitt390's Avatar
Bullitt390
For example, % of error, like +/- 5%?
Not sure. I am sure there is some amount of error, but no idea what it could be for the ICP sensor, plus the length of wiring, plus the OBD port.
Best case is to back probe the connector directly and take the voltage reading and run the calculations to eliminate all those wiring variables.
But I likely wouldn't read into it that much and use the OBD reading as a decent ballpark.
Josh
Old 04-16-2013 | 09:29 PM
Roasted7's Avatar
Roasted7
I'll get a better idea whats going on as I start to monitor it.
I'd imagine to set the P2287 code it would have to be way obviously out. At least for a brief moment.
This kinda sucks. I'm going on a 3000 mile trip this Friday.
Old 04-16-2013 | 09:37 PM
Bullitt390's Avatar
Bullitt390
With the early 6.0 the ICP connector pigtail becomes oil soaked and goes whacko... The fix is a new ICP sensor and updated pigtail.
Josh
Old 04-16-2013 | 10:01 PM
BLADE35's Avatar
BLADE35
ICPV should be 0.18volts--0.24volts at KOEO
Old 04-16-2013 | 10:04 PM
Roasted7's Avatar
Roasted7
Thanks Blade!
JF492
07-29-2017 02:16 PM
redraider25
06-30-2016 10:28 AM
lonecountryboy
17
02-09-2010 09:59 AM
gold101
1997 - 2003 F150
10-20-2007 09:22 PM
amaviper
Aerostar
10-20-2007 06:25 PM
Quick Reply: Proper ICP Volts?
