one random question dealing with engine and rearend setup
Old 04-20-2013 | 03:34 PM
Dtmaster2008's Avatar
Dtmaster2008
And we also chalked it, and came up with one wierd end result...with the truck off we jacked up the rear tires, put it in drive and calculated a 1.5 per wheel turn(it also is not a posi as both wheels did not turn at the same time). It did not make since as common sense you dont have to multiply or divide to get a more accurate answer so yea that was a doozy.
Old 04-22-2013 | 10:00 PM
xkpsanit's Avatar
xkpsanit
That would be your spider gears splittin up your rotation. If the tag is present , i would assume its was correct, and back up that assumption with your tach at road speed
hansol04
24
07-19-2019 02:34 PM
User 71024
07-17-2017 04:52 AM
jgavac
10-27-2014 10:23 PM
fusioncom
20
08-30-2006 07:34 PM
kewlcracker
09-11-2005 08:08 AM
Quick Reply: one random question dealing with engine and rearend setup
