Coolant ?
Old 06-03-2003 | 11:17 PM
Starratt04's Avatar
Starratt04
Coolant ?
hey i have the red coolant in my truck and i dont know if the addative has been added or what. Where can i get the test strips at? also how much do they cost? are they easy to use? thanks
Old 06-04-2003 | 06:36 AM
Motoxman_117's Avatar
Motoxman_117
Coolant ?
I am using evans waterless coolant system. It requires no additives ever and it last for 500,000 miles or so. Do a search for it.
MotoX
Old 06-04-2003 | 07:58 AM
powerstroker250's Avatar
powerstroker250
Coolant ?
Your truck is a 99 so it should of had green coolant. The red or gold coolant is extended life coolant and is not compatble with the seals in that engine. You need to flush your cooling system, get low silicate antifreeze and FW-16 additive.
Old 06-04-2003 | 06:46 PM
Starratt04's Avatar
Starratt04
Coolant ?
Hey i bought valvoline max life antifreeze. the liquid is green and its in a red plastic container.. Is this kind ok?
Old 06-05-2003 | 08:02 AM
powerstroker250
Coolant ?
I don't know. I know that Quaker State and Zerex G50 are ok.
Old 06-05-2003 | 12:22 PM
Starratt04's Avatar
Starratt04
Coolant ?
sorry its not valvoline. its zerex max life antifreeze. it says on there thats it can be used in a cummins.
Old 06-06-2003 | 07:49 AM
powerstroker250
Coolant ?
No max life coolants to be used in your truck
Old 06-07-2003 | 01:37 AM
Jerrybo66's Avatar
Jerrybo66
Coolant ?
When I changed my coolant I didn't relize the PSD was so picky, and I put the wrong stuff in it... I drained out the new coolant, researched the recommended specs, and put Max Life , made by Valvoline in it with FW-16 additive. According to their Web site, Max Life match recommended specs...I'm not going to drain it again ...
Old 06-08-2003 | 01:57 PM
Starratt04's Avatar
Starratt04
Coolant ?
ok cool thats what i have but i dont think mine has the addative in it but im gonna buy it from ford. thanks!
Old 06-08-2003 | 07:04 PM
yavapai's Avatar
yavapai
Coolant ?
does anyone know what seals are involved and what it would take to replace them ? i have had the red coolant in for 2 years and everthing seems to be holding up. F250 born july 98.
Old 06-08-2003 | 08:32 PM
ryanben's Avatar
ryanben
Coolant ?
Does anyone know what kind of coolant is a 01' PSD? It is getting to be that time to change mine and I don't want to buy the wrong kind. Also what is a good brand to get?
Old 06-09-2003 | 12:49 AM
Motoxman_117
Coolant ?
I got 10,000 miles on my evans waterless coolant so far and i dont think it would hurt your seals. Read up on it. https://www.evanscooling.com/main23.htm
I dont have any affiliation with them i just didnt want to go through the hassle of deciding what to use and adding sca`s all the time.
Lee
